Re: M Farmall Info
r4etired
02-18-2007 18:17:02
If it has a cable operator it is a Behlen. the cable enters the trans thru the second bolt down on the right side.about 1/3 way thru the trans, the cable connects to a linkage arm that pivots on a special pin that replaces the pin holding the reverse counter shaft in place. Where the cable enters the trans there is a small compression nut. It threads on the outside of the cable, the bolt is tapt for the outside of the nut,This locks the cable in place and seals from oil leakage The pulley drive gear is replaced with a double gear, one original one with about 15 more teeth, the inside of these gears have .8 square dog drive,two pins run thru the gears for shiftlng Heisler also made a 9 speed,it has hard linkage into the left side, MandW used hard linkage on the right side, With standard rear tires they all gave speeds of 7 9 12 15 mph
