MD Antifreeze in Oil
tom errth
02-18-2007 18:29:20
As I was changing oil in my MD yesterday I seen antifreeze coming out with the oil. I pulled the Head off and could see a tiny little crack between the intake and Exhaust valves, could this be causing it or are there cracks that I cant see doing it. Also when I took the head gasket off it said bottom which was facing towards the head, could this also have caused it. I will be taking it to town to get it magnafluxed soon. If the head is cracked can it be fixed? Any Ideas?
r4etired
02-19-2007 06:37:55
 Re: MD Antifreeze in Oil in reply to tom errth, 02-18-2007 18:29:20
A cracked head on a MD is very common, IN the 50's they were popular in our area. Whenever guys would shut them off hotafter working them hard a cracked head resulted. Midwest Head in Nevada Ia can fix them,Most generally they will have a repaired one on the shelf for exchange,
georgeky
02-18-2007 18:36:38
There could be more cracks. In most cases heads can be repaired.
