bent wide front
garyiniowa
02-18-2007 19:13:07
I found a wide IH front still on a 706 that is bowed has anyone had luck straitening one?
glennster
02-19-2007 07:06:13
 Re: bent wide front in reply to garyiniowa, 02-18-2007 19:13:07
if its just the axle tube and its not cast, should be no problem to straighten it. 10 ton porta power should straighten it out no problem, i would bend it cold, so you dont anneal the steel. if you dont have access to a porta power, a hydraulic bottle jack 10 or 20 ton, and an i beam or piece of railroad track. if the middle is bowed, chain the center to the beam, and push up on each end till straight, if the center is low, chain the ends and push up on the center.
sd pete
02-19-2007 03:53:06
I have never bent one. But if it can be straightened weld a chunk of channel under it. Seen this done many times on loader tractors.
Allan In NE
02-19-2007 04:12:40
 Re: bent wide front in reply to sd pete, 02-19-2007 03:53:06
There's an ol' boy over across the hill that's got a loader tractor front end equipped with an underslung bridge truss and then the two knees are pulled together via a chain and small boomer.
I don't see how you'd ever bend one either. Usually, those knees snap out from under 'em first.
Allan
Harold Hubbard
02-19-2007 05:56:11
 Re: bent wide front in reply to Allan In NE, 02-19-2007 04:12:40
If it keeps doing that long enough it will eventually cut the pin off and set you on the ground. I did that once with a Super C.
Allan In NE
02-19-2007 06:05:32
 Re: bent wide front in reply to Harold Hubbard, 02-19-2007 05:56:11
Yeah,
I'll have to put the wrenches to 'er and tighten the cinch down. I wondered why it had a bolt in there originally. :>)
Allan
sd pete
02-19-2007 05:01:23
Sounds like he might be in the market for a new front end. :))
Allan In NE
02-19-2007 05:16:51
 Re: bent wide front in reply to sd pete, 02-19-2007 05:01:23
My Hydro 70 has had a "clunk" sound in it ever since I put on the 66 series front end.
Finally found it the other day. That darned left pin hole is elongated a bit and it lets the inner tube "roll" about 1/8" when I change directions.
Doesn't hurt anything, but it sure drives me crazy! :>)
Allan
Hugh MacKay
02-19-2007 02:03:53
Gary: I never tried to straighten one, however my first concern is, will it stay once you've straightened it. I 've put these wide fronts through a lot of punishment in my day, never saw one bend. I find it hard to imagine what anyone could have done to bend it. I think I'd walk away.
