706 IH 310D Engine
MJH in WA
02-18-2007 21:27:46
Did rebuild on engine,running good. When I put it in gear nothing happens,anyone out there have an answer? Also where would I find the hydrolic filter?
Thanks in advance for any help given
Mike
Nat 2
02-19-2007 07:55:51
 Re: 706 IH 310D Engine in reply to MJH in WA, 02-18-2007 21:27:46
First, get yourself a manual for that tractor, even an I&T service manual. This tractor is WAY too complicated to just guess at.
I'm kind of baffled as to how you could have rebuilt the engine and not know where the hydrAUlic filter is. It's located underneath a cover below the right brake and the brake pedals.
As far as why it doesn't move... As I said, this is a pretty complicated tractor and there are literally dozens of things that could be preventing it from moving. Does the clutch "feel" like it's doing something when you let it out? You should be able to hear the engine change RPM slightly and hear the transmission spin up when you let it out.
If the hydraulic filter is so plugged that it's keeping the tractor from moving, you've got bigger problems.
I suspect that something didn't get put back together right.
If the hydraulic
El Toro
02-19-2007 04:01:38
Were there cap screws in the clutch used to compress the springs that were not removed? Hal
