New Engine Break-in
1950 mfd
02-19-2007 11:05:33
Hello. I have recently rebuilt the engine in my 1955 400 Farmall. What is the best way to break in the motor if I don't have easy access to a dyno? TIA for any replies.
1950 mfd
02-19-2007 17:48:13
 Re: New Engine Break-in in reply to 1950 mfd, 02-19-2007 11:05:33
Thank you for the answers guys! Manure detail is one of the jobs I have in mind for the old girl. When driving down the road I will just vary the RPM every couple minutes. Thanks again!
Brownie450
02-19-2007 15:11:24
Steve is right on with the manure hauling. A little idle--a little load. Lets all the bearings & rings, seals---everything get broken in easily. That's the way we broke in engine overhauls, & have had good success.
glennster
02-19-2007 12:02:35
heres how i break in a rebuilt. dont run the tractor at full load for at least 10 hours. best thing to do is run her around in third or 4th gear, vary the rpm from idle to about 1/2 to 3/4 throttle for a day. try and avoid long periods of the same rpm until the rings break in. keep an eye on the oil pressure . get a couple days of running on it before you run er hard with a full throttle load.
steveormary
02-19-2007 14:55:29
 Re: New Engine Break-in in reply to glennster, 02-19-2007 12:02:35
glennster
We would put our new tractors on the manure spreader for breakin purposes. Worked good for us.
Overhauled the engine in the super M and broke it in pulling 3-14"s plowing alfalfa ground.
I would think the main thing is to run them at the proper operating temp. and make sure they dont overheat.
