Front Wheel Bearings on H
jc newton
02-19-2007 17:44:36
How do you get the wheel bearing race out of hub without destroying the grease retainer thats behind race?
Nebraska Kirk
02-19-2007 19:25:57
 Re: Front Wheel Bearings on H in reply to jc newton, 02-19-2007 17:44:36
There are a couple of notches in the grease retainer, just run a long punch in that notch and tap on the race, alternating sides untill the race is out.
Janicholson
02-19-2007 19:23:59
Most of the time the seal is replaced when the hub is disassembled. If the bearing race is driven out with a brass drift from the opposite side, the seal often pops out any way often not dammaged. Getting it out cleanly may require a slide hammer with a home made spoon that can go behind the seal to gently work it out. They are pretty inexpensive, so why not replace it. JimN
