In July the high line to the rear lift cylinder blew. took a while to work off the frozen control valve connector, so the hose was disconnected at the cylinder (but plugged) during that time. I suppose it could have picked up some moisture then, since it sat under a tarp for 2 months (I"m a slow worker!). I finally replaced the line and started her up, after a few minutes I got pressure and its worked fine ever since for road scraping, snow removal etc. I didn"t add fluid. When it stopped working, it made noise and had a lot of choppy stuttery vibration, then quit lifting, then slowly dropped my front bucket and backscraper down. Can"t move it off the road. The noisy pump sound stopped and I was guessing low fluid let air in somehow. No change after I added fluid, wouldn"t move the pistons to work out any trapped air. Ok, I won"t crack a line to test. Now sounds like it might be a frozen water in the line somewhere. We had a big thaw today around 40 deg, so I"m hoping the problem goes away. I don"t see how the strainer is the problem unless it suddenly clogged up, which seems unlikely. I"m thinking about heating with a torch, but haven"t a clue where the ice block might be, if there is one. Any ideas?
