560D oil leak at oil cooler
garyiniowa
02-20-2007 04:46:51
I have a 560 Diesel it has developed a oil lead at what I think is the oil cooler, sitting on the tractor there is a oil leak on the left side of the motor inside the frame rail it has hoses running to it that appear to be cooling hoses from the cooling system, it looks to be bolted on with 2 3/8 studs is this the oil cooler and what does it take to put gaskets or O-rings in it? and do I have to take the engine loose and lift it up to remove the oil cooler? Thanks Gary
ejr-IA.
02-20-2007 10:30:10
 Re: 560D oil leak at oil cooler in reply to garyiniowa, 02-20-2007 04:46:51
Iff you need to take the cooler off to fix it Ive taken the frame rail off then you can get right at it.Just block the clutch houseing up with a jack to support the weight a little.
