any ideas?
markloff
02-20-2007 12:39:59
Hey,
I've got the front end on my SM completely tore down. I've been soaking the entire front end casting in degreaser and wire brushing it (off the tractor) It's obvious I'm never going to get it completely clean this way, especially up into the hollowed out parts of the castings. This 50 some odd year old crap is baked on like asphalt. I'm doing a full rebuild so I might as well get it completely clean. Any ideas? steam cleaner, car wash, pressure washer, hot water in a 55 gallon barrel? What have you guys done in the past?
Thanks,
Mark
shoo_giesty
02-20-2007 21:49:15
 Re: any ideas? in reply to markloff, 02-20-2007 12:39:59
go here
www.fboerger.com
the tractor vet
02-20-2007 15:16:28
Home made hot tank bottom half of a 55 gallon barrel water half way up about 5-6 bottels of Mr. Clean or janitor in a drum and add heat let cook till done . P/S do this out side it stinks big time .
flying belgian
02-20-2007 15:05:01
truck wash. they are set up for just that sort of thing.
the Unforgiven
02-20-2007 14:31:04
How about a hot tank?
SuperA-Tx
02-20-2007 14:03:25
Does the "complete rebuild" include painting it? If so then use oven cleaner a few times to cut the greese and paint. After that then sand blast it to get it to bear metal.
Maark
02-20-2007 13:30:05
If you have access to a cutting torch, I have used the heat to burn the oil out of the grease and then used a wire brush to remove the dried up remnants.
Don L C
02-20-2007 12:53:15
Mark ---
You could try soaking it in de-greaser put it in your trailer and drive too a car wash that has the nozzel type sprayer....Take your scoup shovrl and broom, in case you make a mess.....
sflem849
02-20-2007 12:44:54
First of all, that would be pretty neat if you were soaking it in degreaser on the tractor. I have a mental picture... The part is strong enough to withstand blasting so I may look at that. I once new a guy who sanded everything! That would take forever and still not get into the small spaces. Sorry I couldnt be more helpful.
markloff
02-20-2007 12:50:12
 Re: any ideas? in reply to sflem849, 02-20-2007 12:44:54
I meant spraying on engine degreaser a couple of times a day.
Mark
