lift arm leveler crank
Gary in Mozarks
02-20-2007 17:45:10
Does anyone out there know? The crank handle on my 424 (1965 model) 3 point leveling jack is broken off below the casting. Are they pretty much universal for mid 60's tractors or do I have to find one for the 424-444 series? It't one that sorta comes out the top at an angle, not the one that comes out the side. Thanks
Bob
02-20-2007 17:57:04
 Re: lift arm leveler crank in reply to Gary in Mozarks , 02-20-2007 17:45:10
Have you checked to see if the crank, part # 704 200 R32, is still available?
A "jobber" lift link for a Category II 3-point SHOULD fit, but there can be slight differences in the fit/angle of the clevises, or POSSIBLY pin diameter.
I put an aftermarket unit on a 8N Ford, (also a CAT II hitch), and it DOES work, but looks awkward, compared to the original.
wolfman
02-20-2007 17:55:17
I think the 424, 444, early 484 were the Mahindrs based ones with a little different 3-pt cranks than other IH's.
