Oil leak on Farmall C
Vacherie
02-20-2007 19:07:48
Three years ago I bought a Farmall C. About three weeks ago I noticed a leak from the head.
The leak is new and is over the 2nd and 3rd plugs.
Do I need a new head gasket?
Roger Mills
02-21-2007 07:09:57
 Re: Oil leak on Farmall C in reply to Vacherie, 02-20-2007 19:07:48
My A is leaking oil at the same place. Was told that engine just overhauled so will try to re torque the head-but ordered a gasket set because I don't think any sealer was used on the gasket.
leon
02-21-2007 02:33:57
You didn't say if if is leaking coolant or oil, but either way retorquing, may help. Then if it is lealong coolant, though it's against my religion and I use it only because it sometimes works, try some radiator stop-leak. Again, sort of against your religion I'm guessing, but your local John Deere dealer sells a really good JD branded stop leak.
gene bender
02-21-2007 01:21:47
Thats not uncommon to see a leak there same thing happened last summer three yrs after o-haul so i cleaned the spot ground clean with a die grinder and used fiberglass resin stopped it clean. The oil passage going to the rocker arms is rite behind that area.
Vacherie
02-20-2007 21:29:20
 Thanks in reply to Vacherie, 02-20-2007 19:07:48
For the feedback
georgeky
02-20-2007 21:17:55
You can retorque head(in proper sequence) and it may stop the leak sometimes it works and sometimes it dont. If not you will need a new head gasket.
riverbend
02-20-2007 19:24:01
If the oil is coming from above the plugs, you might need a new valve cover gasket. The head gasket is located below the spark plugs. When you do the next tune up and adjust the valves, replace the v/c gasket. When you have the cover off check to see that the oil drains are clear. In the mean time, just keep an eye on the oil level.
Greg
Vacherie
02-20-2007 19:40:48
 Re: Oil leak on Farmall C in reply to riverbend, 02-20-2007 19:24:01
I described the leak location incorrectly. It is betweem the head and block.
