Farmall H Remote Control Valve/ Aux. Control Valve
John in Ct
02-21-2007 09:46:55
I am working on a Remote Control Valve/ Aux. Control Valve ( converts one way hyd into two way)for my Farmall H. My questions, how do you adjust the 2 nuts on the spool? Is the control rod that is used with it the same diameter as the Lift-All control rod? Mine is worn so I want to make a bushing. Thanks!!
PatMz
02-21-2007 11:26:16
 Re: Farmall H Remote Control Valve/ Aux. Control V in reply to John in Ct, 02-21-2007 09:46:55
The control rod on my M aux valve is the same diameter as the liftall rod.
I'm not sure what nuts you're referring to, I don't recall any adjustments. The parts lists for the two are identical, except for the brace to the gas tank bolt.
Is this the dude?
third party image
Mark Johnson
02-21-2007 16:02:16
 Re: Farmall H Remote Control Valve/ Aux. Control V in reply to PatMz, 02-21-2007 11:26:16
A little off topic but how did you get the parts printed and copied so well to the forum?Thanks
Mark
PatMz
02-22-2007 05:16:04
 Re: Farmall H Remote Control Valve/ Aux. Control V in reply to Mark Johnson, 02-21-2007 16:02:16
I used the CNH online parts search:
Click Here!
Then I copied the picture and uploaded so I could link to it.
John in Ct
02-21-2007 12:29:33
Thanks for Replying!!! That is the valve. The 2 nuts that I am not sure how to adjust are #6 in the diagram.
D Slater
02-21-2007 14:39:38
 Re: Farmall H Remote Control Valve/ Aux. Control V in reply to John in Ct, 02-21-2007 12:29:33
To adjust if all the lines are out of ports I think you can look through rear ports and tell when spool is in center. If its on tractor adjust until you get pressure at one port then the other by moving lever the same distance from center. You can adjust with rear ports dead headed,just listen to engine start to labor.
PatMz
02-21-2007 14:23:05
I'm sitting her tapping my foot waiting for Allan, Hugh, Bob M and the other people who really know to chime in.
The names of those parts are:
4 AUXILIARY CONTROL VALVE CENTERING SPRING 5 AUX. CONTROL VALVE CENTERING SPRING WASHER 6 AUX. CONTROL VALVE CENTERING SPRING SPACER 7 AUXILIARY CONTROL VALVE CENTERING SPRING LOCK
Looks like you adjust that nut so the spring returns the valve to center, i.e., no fluid moving through either hose. All the parts are "retired", so don't do what I usually do in these situations and drop a little piece in the shop floor debris!
