Steering shaft
JRS
02-21-2007 13:17:57
Took the steering shaft out of my M today. Shaft metal was worn way done and sloppy. The center steering Bearing had a brass sleeve inside of it. Is this normally a part. Looked like an add on to me. know of where to find a replacement for this?
georgeky
02-21-2007 13:36:54
 Re: Steering shaft in reply to JRS, 02-21-2007 13:17:57
That is it they are equipped with bushings. I dont know if they are available at IH or not. You can have them made. You can build the shaft back up.
