Order Farmall Cub Parts Online
Cub Wheels on an A
DelMN
02-22-2007 04:51:59
Will Cub rims fit on a Farmall A?
Thanks,
Farmall Freak
02-22-2007 14:48:33
 Re: Cub Wheels on an A in reply to DelMN, 02-22-2007 04:51:59
I wouldn't do it because it is not original and wouldn't look too great.
Jim Becker
02-22-2007 08:20:31
The bolt circle is not quite the same so you need to do a little modification, but it has been done. Yes, I am refering to the bolts at the rim, not the hub.
Also, the offset of the lugs is different. That affects where the track ends up. Depending on what you are trying to do, it may not make any difference to you.
gene bender
02-22-2007 05:57:14
the rims will but not the center section therefore you could have 10in rims on a CUB what a sight a CUB with 15.5s
