Cu -v- Regular head gasket
Tom Windsor
02-22-2007 22:01:54
There was a question on here about where to find a copper head gasket for an H.
There was a response that Lubbock makes the copper and regular gaskets. My question is, what is the decision process as to whether to use a copper or "regular" gasket? are there advantages of one over the other?
TW
Janicholson
02-23-2007 06:34:09
 Re: Cu -v- Regular head gasket in reply to Tom Windsor, 02-22-2007 22:01:54
Copper "gaskets" are primarily for containment of combustion pressures in modified engines. As Rusty indicates they also raise compression a bit. They are not the right stuff for general purpose repair as they are much less compliant to slight surface imperfections, and bolt tightness variations. More of a racing solution. They are very good when sealing extreme pressure, They also conduct heat very well. JimN
RustyFarmall
02-23-2007 02:56:50
Don't quote me on this, but I think the copper gasket is thinner, which would increase compression, in turn increasing horsepower.
