Air Lift Q for Gene Bender or ?
Roger Mills
02-23-2007 07:12:25
In need of the pipe from the exhaust diverter to the control valve. Mine has been cut, spliced and twisted. By the by, how many different cylinders and push rods did they have-I have seen short ones mounted vertical on front and long ones, (like mine), nearly horizontal at rear. email is open.
Roger Mills
02-23-2007 09:28:02
 Re: Air Lift Q for Gene Bender or ? in reply to Roger Mills, 02-23-2007 07:12:25
Thanks Gene, I think that is why the pipe I have was cut and ended up twisted. I have to remove the diverter from a cracked and busted manifold. It is off and soaking now. Hopefully I can get them apart. Lift system worked perfectly but leaked down until I pulled the piston out and soaked it to swell the seal. I used soapy water and it now holds pressure for several hours. Do you have any diverter parts-like the base if I break it?
gene bender
02-23-2007 09:08:35
The cyclinders are all the same but different pipes that go over the rod on the piston were used as they were used as "pushers" and also had a slug used to secure a cable like on the cultivators. To replace the pipe it is easier to use a union and two 90s and nipples for length as the only way to use the original one piece is to have the pressure valve on the manifold loose and turned to get the pipe screwed on and when the pressure valve is rusted on the manifold can be a problem as sometimes using heat it can ruin the threads. glad to help anytime as these systems are great when properly maintained. I have used them since 48 therefore am a great believer in them.
