M Early Super M interchangeable parts?
Bruce Shaver
02-23-2007 14:06:59
Are the following parts from a M OK to use in the restoration of an Early Super M: Hood, Grill, Magneto and Carb?
randy hall
02-23-2007 19:03:29
 Re: M Early Super M interchangeable parts? in reply to Bruce Shaver, 02-23-2007 14:06:59
the carb will bolt on but the choke rod won't hook up because the choke lever is on the inside on the super m's, outside on the straight m's.
CNKS
02-23-2007 17:18:39
The M carb is jetted and adjusted different, but it should still work. The grille will have the holes for the Farmall emblem, rather than IH, and will not have the wide-spaced holes on either side that the Super M may or many not have. I suppose the mag will work as it was an option on the SM, distributer was standard, the advance curve may be different. As far as I know the hoods are identical.
georgeky
02-23-2007 14:32:23
Yes they will fit.
Charlie M
02-23-2007 17:09:43
 Re: M Early Super M interchangeable parts? in reply to georgeky, 02-23-2007 14:32:23
They fit but aren't they different. Early M grill might have the cut out for cultivators, super carburators are different and I think the Farmall emblem looks different but not positive.
georgeky
02-23-2007 17:40:45
 Re: M Early Super M interchangeable parts? in reply to Charlie M, 02-23-2007 17:09:43
Yes they are different but will work. The Super M does not have a Farmall emblem it is IH logo.
