IH 884 dsl hydraulics
Ted Leigh
02-24-2007 13:38:51
I have an IH 884 dsl. After starting to whine loudly, my hydraulics quit and now I can"t move the tractor, either. The hydraul. fluid level is good. I"m told that it sounds like a clogged filter; in addition to the filter with the O-ring on the side of the trasmission I"ve heard that there might be a separate screen filter. My operator"s manual shows neither of these. Does anyone know if there is a sceen and where it is? Where can I find a schematic that"s more complete than the operator"s man.?
Thanks for your help, Ted Leigh York, PA
Fromjb2
02-24-2007 20:44:43
 Re: IH 884 dsl hydraulics in reply to Ted Leigh, 02-24-2007 13:38:51
Hi Ted, is this is a gear drive 884 not a Hydro correct? Does it have a T/A? If it is a gear drive with T/A it should go in any gear in LO T/A. HI T/A requires hydraulic oil from the return line from the oil cooler for the supply for the T/A pump. But LO T/A is mechanical srag clutch.
Has it warmed up to above freezing in PA yet?
Could be ice in the hydraulic filter?
Good luck
JimB
Stubob
02-24-2007 18:03:11
Go to the IH website and click on search for parts. Type in your tractor model number and you should get a list of diagrams for the different parts of the tractor.
