1945 farmall A
Pete-um
02-25-2007 04:02:48
Why does my tractor jump in gear? And also isn't ther a startergenerator available with pulley drive?
Roger Mills
02-26-2007 08:18:55
 Re: 1945 farmall A in reply to Pete-um, 02-25-2007 04:02:48
No hole for starter on bell housing? I thought that the '45's all had them. Find a casting code to check the year of the housing. You might have a '45 engine in an earlier tractor, someone might have replaced the tag to match.
Pete-um
02-26-2007 17:20:59
 Re: 1945 farmall A in reply to Roger Mills, 02-26-2007 08:18:55
bought it from original owner nothing has been changed
tn terry t
02-25-2007 05:28:55
there are many causes for the trans jumping out of gear if that is what you mean shifter worn or bent bent shifter forks i would pull the top of first and have a looksee never heard of a starter-generator strong enough to start that motor. what yours dont have the hole for the starter? or does it have the hole with no ringgear?
Pete-um
02-26-2007 03:25:59
 Re: 1945 farmall A in reply to tn terry t, 02-25-2007 05:28:55
It does not have a hole for starter. And yes it jumps into gear before I can get on. Don"t want to get run over.
