1466 Power Steering
Steve Mahac
02-25-2007 10:02:06
With Michigan's ice storm here today, I had the need to fire up my 1466 to pull my skid steer out of a ditch (long story). My IH has not been used since last fall. I was suprised to find out I had no steering which I found out while already moving forward at a brisk pace. I found the hydraulic fluid to be low, but after refilling the fluid, still no steering. Any hints on where to look first?
Jay IH Man
02-25-2007 17:22:46
 Re: 1466 Power Steering in reply to Steve Mahac, 02-25-2007 10:02:06
First find a 5/8 wrench and remove the only plug on the MCV valve located on the left hand side of unit, the plug is towards the rear of tractor.
There is only one that is 5/8,this opens the steering orfice,crank over tractor with plug removed,this is messy and will shoot oil out of unit after a short time.when you have a steady stream replace plug and you will have steering. If you use this unit in cold weather go to your Case dealer and purchase a hyd. suction sreen for a 7100 series magnum tractor. Grind off rubber gasket to the same size of your hyd filter that you have removed.Install the suction screen instead of filter and this will help you in winter time operation. We have done this for customers that have slow or no hyds. in cold weather,this works on 06,26,56,66,86,88 series tractors as well.
Steve Mahac
03-05-2007 15:43:47
 Re: 1466 Power Steering in reply to Jay IH Man, 02-25-2007 17:22:46
Jay,
I removed this plug and the oil only dribbled out. I started the engine and still a dribble. Removed the hydraulic filter and screen on the left side and the screen was clean. Have another filter ordered but the old one was clean. What do you think I need to do next?
