Super C Belt Pully Drive Gear
L MACK
02-26-2007 20:21:47
I have a running Super C with no belt drive PTO. I was able to purchase a drive to replace the blank above the standard PTO. However there was no drive gear inside the blank. The shaft had a nut and cover sleve but no key way. The shaft was completely smooth. Is a Key Way required for the drive gear? I have replaced the blank since there was no drive gear.
Haas
02-27-2007 10:15:41
 Re: Super C Belt Pully Drive Gear in reply to L MACK, 02-26-2007 20:21:47
The parts info shows a 3/16 thick x 7/8 wooddruff (half moon) key. I'm very surprised your shaft has no slot for it. I wonder if you have just missed it and the slot is full of grease or other crud. The woodruff key slot does not come out to the end of the shaft. These gears are pressed on really tight, but I think you still need the key. You are not the first one I've heard that wanted to add a belt pulley and got caught by not getting the drive gear for it. Always make sure you get the gear with a pulley set up for the C, Super C, Super A, etc. The gears are not all the same, so you need the one that mates to the drive you get.
