450D shift lever
Bill46
02-27-2007 05:03:07
Working on the 450D and decided I want to fix the shift lever. Every once in awhile it gets stuck between 1st and reverse. Then I have to stop and pull the pin out, remove the lever and set the slide rails.
Is there anyone that makes a replacement? Can the lever be built up with a welder?
Tractor works ok, but the shift lever is a pain in the backside.
Thanks for your help.
flying belgian
02-27-2007 06:50:52
 Re: 450D shift lever in reply to Bill46, 02-27-2007 05:03:07
afor mentioned post is exactly right. I had the same problem with 560. took 2 weld and grind trys and then it worked perfect.
georgeky
02-27-2007 05:34:32
Bill you can build that up by welding. You may have to work on it 2 or 3 times to get a good fit, just weld and grind until it fits in rail better.
