Diesel 282 Flywheel to a Gas 263
elrod62
02-27-2007 09:47:22
Will a diesel 282 flywheel bolt on to a gas 263? I"m replacing the 282 in a 656 with a 263 out of a 615 combine. Flywheel in the combine will not work on the tractor.
Armand Tatro
03-01-2007 07:18:05
 Re: Diesel 282 Flywheel to a Gas 263 in reply to elrod62, 02-27-2007 09:47:22
What are you going to do with old engine? I am interested in some parts. E-Mail me at corn.sheller@hotmail.com and let me know how to contact you. Armand.
Armand Tatro
02-27-2007 18:16:57
Why are you going from a diesel to a gas engine? Armand
elrod62
02-28-2007 03:56:32
 Re: Diesel 282 Flywheel to a Gas 263 in reply to Armand Tatro, 02-27-2007 18:16:57
Going from diesel to gas because the diesel is worn out. Those old diesels are hard to start even in good shape. The gas engine is like new, and readily available.
Mich John
02-27-2007 13:02:14
Best also look at the weight and Inertia differences. The diesel probably is greater for both which means the gas engine will NOT rev as quickly with the diesel flywheel.
elrod62
02-27-2007 10:41:49
I plan to use the diesel starter, that should eliminate the ring gear difference.
Tractorman NC
02-27-2007 10:23:56
They may bolt up but parts book gives different part # for C291 and D282. Ring gear is different also.
Owen Aaland
02-27-2007 22:10:25
 Re: Diesel 282 Flywheel to a Gas 263 in reply to Tractorman NC, 02-27-2007 10:23:56
The crankshafts are interchangeable on these engines. The flywheel will bolt up correctly.
