H and M steering gears
John S-B
02-27-2007 19:38:11
I'm gonna take apart the steering on the M and see if I can tighten it up a bit. Does any one know if the parts for a narrow front H and M are the same? Mine is a '45 model M. I saw some H parts for sale and I wondered if the steering gear parts are the same. Just trying to plan ahead.
Armand Tatro
02-28-2007 15:40:05
 Re: H and M steering gears in reply to John S-B, 02-27-2007 19:38:11
Where do I find these Carter & Gruenewald bushing kits? What else do they have for sale. Armand
glennster
02-28-2007 06:58:01
carter and gruenewald sells a rebuild kit for the h and m bolsters, has upper and lower bushings bearings seals for about 150.00. that will tighten her up pretty good. its probable that the worm and sector gears are worn out, i replaced them a couple years ago on an m, got them from case i-h, ran about 650.00 for the set
John S-B
02-28-2007 14:15:31
 Re: H and M steering gears in reply to glennster, 02-28-2007 06:58:01
Well thanks for the info, I opened 'er up and it's a little of everything. It looks like I can tighten some bolts on the u joint and I have the 360 degree sector gear so I can just turn it, it had plenty of lube though. The bushings for the bolsters definately need replaced and I think I'm gonna put new wheel bearings in too.
Dave 2n
02-28-2007 07:02:12
Also--check the u-joints on the steering shaft; a little looseness there gives a lot of slop at the front wheels.
Wild Bill
02-27-2007 20:35:08
No, not the same. everything on an M is bigger than an H. (except the wheel base, but that is another story)
