Stuck piston and sleeve
HENRY E NC
02-28-2007 11:14:21
I got it. Actually I have all four sleeves out ofvthe block. I still have to cut one piston out of it's sleeve but that is not a problem. Out comes the cutting wheel. I used a piece of rebar, ground it smooth and flat to go around the rod and then just beat on it with a 4 Lber untill it came loose. The rest came out with a 2x4 and piece of flat steel. Thanks for all the help and suggestions. Henry
FarmallBob
02-28-2007 13:47:43
 Re: Stuck piston and sleeve in reply to HENRY E NC, 02-28-2007 11:14:21
Henry,
Won't you be deeding that sleeve that the piston is in? How will you get another one to match? They usually come in sets all matched up.
Bob
El Toro
02-28-2007 13:46:17
If you have a torch heat that sleeve and see if the piston will come out. Hal
HENRY E NC
02-28-2007 20:15:04
 Re: Stuck piston and sleeve in reply to El Toro, 02-28-2007 13:46:17
Actually all the sleeves are bad rusty so I am replacing everything in the engine block except the cam and crankshaft and rods. I had to cut the #1 piston out of the sleeve to save the rod. Next is a good cleanup, nickel wwelding the crack in the block and starting to go the other way.(Installing new parts.)
