404 or 444 Crank ??
VinnyJimbo
03-01-2007 07:37:11
Just tore down what I thought was a IH 404 motor and found that the crank, main and rod journal specs, don"t match what my IH-201 shop manual says they should be for a 404. The numbers I measured seem to match the specs for a 444. Can anybody tell me whats goin on here? Could the manual be wrong? The crank casting number is 375600R-1. Need to know cause I plan on buying a rebuid kit and want to get the right one. Thanks
ejr-IA.
03-01-2007 15:32:35
 Re: 404 or 444 Crank ?? in reply to VinnyJimbo, 03-01-2007 07:37:11
Serial no. below 100500 crank is 2.2444/2.2450 and above 100500 is 2.6235/2.6245
ejr-IA.
03-01-2007 17:24:53
 Re: 404 or 444 Crank ?? in reply to ejr-IA., 03-01-2007 15:32:35
OK the rod specs. are 2.0590/2.0600 Clevite bearing No. rod is CB-533P comes in 10 20 30 under.Mains MS-665P 10 20 under.I Guess standard too.
Vinny Jimbo
03-01-2007 15:43:39
 Re: 404 or 444 Crank ?? ejr-IA how about rod jour in reply to ejr-IA., 03-01-2007 15:32:35
Thanks very much for the help. Can you give me the spec for the rod journals to ? I really appreciate it.
ejr-IA.
03-01-2007 09:36:29
According to the book I have that number is for a 404 crank no. 375600R fits 135 and 146 cid.
VinnyJimbo
03-01-2007 12:55:46
 Re: 404 or 444 Crank ?? in reply to ejr-IA., 03-01-2007 09:36:29
What I was trying to say was crank journal dia for 404 in my book says 2.1245. Crank measures 2.620 which is about what the dia is for a 424 or 2424 or 444 or 2444. I"ve nosed around in this forum and I"ve seen some words thta say the later ser num 404 (100501 and above) has a larger dia crank than earlier numbers. I"m beginin to suspect that my manual list specs for older ser num 404. Just looking for confirmation.
El Toro
03-01-2007 13:40:29
 Re: 404 or 444 Crank ?? in reply to VinnyJimbo, 03-01-2007 12:55:46
The Farmall M had the same situation, they had 2.7474"-2.7485" on the crankshaft main jouranal
up until S/N 278049 and on the rods 2.4975-2.4985".
From S/N 278050 and up the shaft measured 2.8075-2.8085" on the mains and the rod journals meassured 2.5475"-2.5485". Hal
