Snap On Duals
Caistor Centre
03-01-2007 10:28:58
How do snap on duals attach to a tractor?? Does anyone know if any photos are posted somewhere on this site or elsewhere on the internet. (I have not been able to find any)
I see snap on duals advertised at lots of upcoming auction sales, but I don't know what is required to add these to my tractor.
Thank you
JTinNJ
03-02-2007 16:35:46
 Re: Snap On Duals in reply to Caistor Centre Guy, 03-01-2007 10:28:58
The first week of Jan I found a IH 966.After making the deal the farmer asked if I wanted the set of duals for the 966.I asked how much did he want for them.He told me if you want them there yours. Now I have a set of snap on duals. They look just like what Allan has in the pictures.But,mine do not have that much tred on the.What do you want for free?
Caistor Centre Guy
03-02-2007 14:12:22
Thank you very much for all the info gentlemen. It is much appreciated.
John A.
03-01-2007 21:30:45
C.C.G., Last April I picked up a set of Smap-on style duals at an Auction about 80 miles from me.
As most guys here will tell you is....The Snap-on style are Not highly prised usually unless they have a bunch od tread left on them. I was prepared to go fairly high. The Auctioneer started out high and No one bid, he kept comming down till I bib! No one else bid, so I got my set. They look real close to Allans set in his pic. But my set has maybe 30% rubber. OBTW I only gave $2.50 for the pair TOTAL.
What I didn't get were those Eyed-nuts just like the ones in Allans pic. Those little Jewels run about $4.00 ea from Underverth Mgf Co. All eight cost $32 then $4 shipping so the setup I have has been very cost effective. I will bet you can get a set given to, of bought cheap. Mine have 4 J-bolts that secure each to the mounting wheel, at some point I will add 2 more /wheel to keep them tight, mine tend to keep loosening up and working back and forth. Good Luck.
Later,
John A.
glennster
03-01-2007 13:56:52
here is what the clamps look like, mine have 4 per wheel
third party image
Allan In NE
03-01-2007 12:09:15
I think snap on duals are the best thing since sliced bread. The only reason I use 'em are for floation tho.
You need the eyebolts/nuts at the lugs of your tractor; typically 4 per wheel. The duals are mounted on a rim that has a wide band or "lip". This band will fit inside and wedge to the tractor rim when tightened up with the cinch bolts.
Allan
third party image
third party image
third party image
