w9 into an m
x-man
03-01-2007 13:24:05
what is required to put a W9 motor into a farmall M ?
Farmall Freak
03-02-2007 15:33:14
 Re: w9 into an m in reply to x-man, 03-01-2007 13:24:05
I would Highly suggest that you don't put the W9 motor in because parts are really hard to find. Just supe up the M motor.
RustyFarmall
03-01-2007 13:28:31
Probably a cutting torch and a welder. I don't think it will fit, and even if it did, it would be tough to find parts for. You can get just as much power out of the M engine if you want to spend some bucks.
Nat 2
03-01-2007 13:28:06
A lot of custom machining.
