2 questions
banjo
03-01-2007 20:38:14
1. On a 1941 H did it come with the friction or notched tooth throttle? 2. I forgot what the other question was
sflem849
03-04-2007 05:41:07
 Re: 2 questions in reply to banjo, 03-01-2007 20:38:14
Not to hijack, but what is the difference between the sawtooth and the notch?
PS - I hate having to put my throttle back. Mine usually jumps two teeth to about 3/4 throttle.
Steven@AZ
03-02-2007 06:47:54
The saw-tooth throttle would be original equipment.
Friction is aftermarket, and I'm not sure about the square notched ones - our SMTA had one of those.
Nat 2
03-02-2007 05:01:10
Glad you forgot question #2 because I forgot the answer :)
Jrry
03-02-2007 07:27:40
 Re: 2 questions in reply to Nat 2, 03-02-2007 05:01:10
I think the answer to question # 2 is maybe.
georgeky
03-01-2007 20:47:37
Notch tooth. The friction type are after market
RustyFarmall
03-02-2007 04:52:15
 Re: 2 questions in reply to georgeky, 03-01-2007 20:47:37
Actually, the original is the sawtooth, the notch tooth came later as an aftermarket replacement. The sawtooth is available new, a bit pricey, but not unreasonable if you an authentic reproduction.
PatMz
03-02-2007 07:07:53
 Re: 2 questions in reply to RustyFarmall, 03-02-2007 04:52:15
OEM has the sawtooth complete, or just the lever. I got the lever, about $26. Sure is nice to be able to set the throttle and not have it "snap back" to 1/2 throttle on every bump!
