mower Tractor,
kirk in ks,
03-03-2007 06:52:16
I wanna put a mower behind this w-6,
But I dont have 3 point,
Just drawbar,
need mower that,s right for this tractor,
loophole
04-11-2007 06:57:36
 Re: mower Tractor, in reply to kirk in ks,, 03-03-2007 06:52:16
I am trying to find photos of a IH model 120 sickle mower to check on how it should be mounted.
I have a draw bar and a 3 point hitch on my Kubota 6800 tractor
NDS
03-03-2007 10:04:16
I pull a 7 foot drawbar pull heavy duty Bush Hog brand rotary cutter with M and it is pretty good match and does excellent job, in tall thick grass it gets to be a little more than M needs though. Around here everyone pulls drawbar pull rotary cutters for anything above 8 foot or so even with new tractors.
Steven@AZ
03-03-2007 09:35:21
What kind of mower? Are you looking to make hay? Then you will need a sickle bar mower. Looking to clean up brush/overgrowth and not make hay? Then you need a brush hog type mower.
They make pull type of both kinds. If you're looking for a sickle bar, go with an IH balanced head trailer mower. Model number would be 100 or 1100. The drawbar mounted mower is a 120 or 1120.
Dunno about brush hog type mowers, never used one.
Kirk in ks,
04-11-2007 17:13:52
 Re: mower Tractor, in reply to Steven@AZ, 03-03-2007 09:35:21
I want a bush hog, or a King kutter 7 ft is ok, I know it'll handle it ok,
Kirk,
Redmike
03-03-2007 07:01:44
I needed a pull type mower for my 1940 H and couldn"t find here that was worth buying. Had an older 3 point shredder that needed some repair and ended up making it a pull type by revising the 3 point to be a tounge, and putting a adjustable axle across the back. Rewelded the decking that had broke loose and the angle iron frame. worked out pretty good.
kirk in ks,
03-03-2007 10:20:59
 Re: mower Tractor, in reply to Redmike, 03-03-2007 07:01:44
Hi Red,'
I was looking at the Rhino,s, and they have some pretty good mower,s with REALLY GOOD WARRANTY,S TO,
5 yr,s on the gearbox and probably that, or not too much less on the whole unit,
Ill get one of these, and then go to town with it!
Kirk,
