manure spreader tires
Keith Wonderlin
03-04-2007 09:17:06
I'm rebuilding a IH 200 manure spreader an need to know what size were the original tires.I think they were probably 750-20 like the New Idea spreaders and corn pickers but I'm not sure.Anyway I am looking for a pair of used ones. Keith
Mark LaVoy
03-20-2007 19:23:23
 Re: manure spreader tires in reply to Keith Wonderling, 03-04-2007 09:17:06
I have reatored a #200 and a #21 IH manure spreader during the last two summers. the original tire size was 7.50-20. I chose the titan tires for both of mine. No other brand looked as well or was as cheap. I had to replace the frames and sides also. Does anyone need parts or want to buy the IH #200. It is in excellent shape with new paint and decals.
Keith Wonderling
03-05-2007 05:00:54
When I started this project I thought it was going to be easy but it turned into quite a job The main angle iron frame had to be replaced the steel sides were all rotted out and had to be replaced.New floor. I had to rebuild the beaters. A lot of cutting,welding and brazing,wire brushing and painting later and its getting to look pretty good.All I need now is some tires and a toung stand and I will be done. I found out this spreader was built between 1941 and 1954.I think it is good for another 60 years. Keith
Haas
03-05-2007 06:03:41
 Re: manure spreader tires in reply to Keith Wonderling, 03-05-2007 05:00:54
Too bad I did not find you earlier. I have some new old stock parts for the 200 spreader, especially some of the wheel hubs with the drive dogs and cams, etc. Also a drag chain bar as well as a complete set of beater bars. I"ve had them for several years and would sell them reasonable.
El Toro
03-04-2007 10:35:12
You can try Gempler's at 1-800-382-8473. Any idea what ply tire would be used on these spreaders? Hal
Wayne from Iowa
03-04-2007 09:33:07
You are right on the 750-20 tire size. I do not know of anyone that makes the closed cleat type. I am restoring an IHC 200 spreader also. Titan tire makes a tire that size but with an open cleat. That is what I purchased for my project. I think they will look fine. I have one used closed cleat tire but could not fine another one so I bought the Titans. Found a jackstand at a salvage yard and was happy about that. Lets stay in touch. Maybe we can help each other.
Wayne from Iowa
03-04-2007 15:13:56
 Re: manure spreader tires in reply to Wayne from Iowa, 03-04-2007 09:33:07
The IHC Spreader is ground driven and made of steel including sides. It has a wood tongue and groove floor however. A closed cleat tire is when the cleats have no open space between them. This Spreader was first marketed about 1940 and was rated 65 bushel. They also made a # 100 smaller Spreader. Fun projects if you can find all the parts. They are old!
Al L. in Wisc.
03-04-2007 10:20:24
 Re: manure spreader tires-- I'm dumb in reply to Wayne from Iowa, 03-04-2007 09:33:07
I like spreaders so I had to read. I"m clueless as to the term open/closed cleat. Is this model spreader pto driven; wood or steel? Glad you folks are preserving the implements - storage is the biggy for them. Thanks in advance for your time/reply.
