motor id
pa belote
03-04-2007 13:59:44
just got this super a. was tole the motor cam out of power unit.
898r 347 an there is a L on the block.
apreciate the help
pa belote
03-05-2007 11:53:39
 Re: motor id in reply to pa belote, 03-04-2007 13:59:44
there aint no number on that tab. was replacement blocks stamped. it got the dip stick on the side near filter like the 130 an 140.
apreciate it
pa belote
03-05-2007 11:53:37
apreciate it
El Toro
03-04-2007 14:48:11
Look under No1 sparkplug near the radiator for a flat spot. It may be coated with heavy paint and there should be an engine number there. Not sure
if the L is for a date code. Someone should know that post on here. Hal
CNKS
03-04-2007 17:24:08
 Re: motor id in reply to El Toro, 03-04-2007 14:48:11
In this case it means the part was cast at the Louisville factory.
El Toro
03-04-2007 18:24:15
 Re: motor id in reply to CNKS, 03-04-2007 17:24:08
Were the Cub engines made there or just parts casted? Hal
