SMTA, STAGE ONE ETC
Tom Windsor
03-04-2007 15:02:00
You guys need to help me out of the woods on this terminology.
What is a SMTA
What is a Stage One M?
What is a Stage two M?
As distinguished from an M and super M?
NDS
03-04-2007 18:44:30
 Re: SMTA, STAGE ONE ETC in reply to Tom Windsor, 03-04-2007 15:02:00
Here is my version some of the Super M changes actually came on last Ms disk brakes, 12 inch clutch, front timing cover that would take live pump to name some. Stage I super M added several engine changes, bigger carburetors, different gear ratios as well as several stronger transmission and differental parts, LP gas option and bigger radiator. Stage II added live hydraulics but I believe belly pump could still be special ordered, 3 bolt starter and battery under seat. Stage III or SMTA added TA, live PTO, new longer clutch housing and longer hood however either live PTO and/or TA could be deleted. Have left out many minor and maybe some major changes.
John A.
03-04-2007 17:29:37
Tom, Here Goes..... .....Start with a regular run of the mill Farmall M ..... add the larger engine , and disc brakes = SM-Stage I, then add Live Hydrolics = SM-Stage II, Then add SC seat assembly, & TA & LPTO = Stage III--AKA-- The entire SMTA series. The SMs culminate in the StageIV or AKA as the 400 The pennicle of the series , with all the refinments. Being the 400 was in the letter series it had no "stage" designation. This is a basic description of the entire SM series taken from Chapter 9, Page 103 of Guy Fays Letter series book. Hope this helps.
Later,
John A.
John A.
03-04-2007 17:34:21
 Re: SMTA, STAGE ONE ETC in reply to John A., 03-04-2007 17:29:37
Tom, I am way too tired to be typing, My mistake,Disc brakes are on the stage IIs Not the Stage Is. Later, John A.
Tom Windsor
03-04-2007 16:29:15
Well, whatever it is and maybe I will get it figured out...It looks to me like it ought be setting im my shop...about 3 tractors back in line for rework...and I am absolutely certain, my wife is going to have a fit. She now complains that "all you do is rebuild them, park them over in the corner and start on another...isn't one enough?" Well, she is partially right, there are 2 G allis chalmers, 1 H Farmall, 1 Regular 85% complete, 1 Farmall Cub 100%, 1 H in progress, and a B John Deere... Well, I do go down the line once per month and start them up...I guess the bright side for her is the Estate Auction. The Auctioneer should have a good time with them! :-) And It keeps me from chasing women...(something like a dog chasing a car).
Andrew Z
03-04-2007 15:15:48
Stage one the same as Regular M (belly pump) but with the 264 engine. A Stage II has live hydo pump added on to that. A stage III is a Super MTA. and a Stage IV is a 400. /There are other changes along the way but thats the basic idea around the stages.
Andrew
MikeinKy
03-04-2007 15:14:27
Stage 1 is a Super M with more power than a M and faster gearing. Stage 2 has live hydraulics and the battery under the seat. SMTA is a stage 2 with torque amplifier added. I think the SMTA has live PTO also.
Dave H (MI)
03-04-2007 15:24:46
 Re: SMTA, STAGE ONE ETC in reply to MikeinKy, 03-04-2007 15:14:27
Hey...why not REALLY confuse him and tell him that the SMTA might not have either the TA or the live power. I hear it's true.
Janicholson
03-04-2007 15:53:25
 Re: SMTA, STAGE ONE ETC in reply to Dave H (MI), 03-04-2007 15:24:46
You arecorrect all options could be deleted, effectively making a SM out of a SMTA, It was still called a SM, it just had no TA wing on the front hood badges. (and no TA or Live Power Take Off. JimN
randy hall
03-04-2007 16:16:33
 Re: SMTA, STAGE ONE ETC in reply to Janicholson, 03-04-2007 15:53:25
jim, a super mta with the ta delete was still a super mta and could still have live pto if it was ordered that way.
Janicholson
03-04-2007 17:06:39
 Re: SMTA, STAGE ONE ETC in reply to randy hall, 03-04-2007 16:16:33
You are correct, I tried to simplify it to one in which both options were deleted, but the possible mutations got to me. JimN
El Toro
03-04-2007 15:07:26
SMTA= Super M with Torque Amplifier. Hal
