Can some one identify this Farmall A plow
Chad from Michi
03-05-2007 08:03:21
Here is a pic from the photo adds and it has the exact same plow as I have sitting in a pile and I would like to identify it as far as model number.
could it be a A-191 or A-192? here is the link to the photo. anyone please help
Chad
http://www.tractorshed.com/cgi-bin/photoads/classifieds.cgi?search_and_display_db_button=on&db_id=166126&query=retrieval
Hugh MacKay
03-05-2007 08:39:22
 Re: Can some one identify this Farmall A plow in reply to Chad from Michigan, 03-05-2007 08:03:21
Chad: I saw that last evening. The model numbers I have from a dealer parts book are A-91, A-92 and A-192. No mention of A-191, not suggesting doesn't exist, however this is a bound book, thus nothing has been removed, and if there was an A-191, I would have expected to find it in there, as it contains all the A, B and HM mounted plows.
Now the hard part, those plows are all so close in looks, it will require a lot of detail to be accurate. Part numbers could help, I didn't delve into that. If you can get some part numbers, I'm sure I could sort it out for you.
Chad from Michigan
03-05-2007 09:26:08
 Re: Can some one identify this Farmall A plow in reply to Hugh MacKay, 03-05-2007 08:39:22
Hugh
I will try to find part numbers but I couldn't find where they were at. I was thinking it was the A-192 becasue it mounted from the culitvator front tool mount. Isn't the others drawbar type?
Chad
Hugh Mackay
03-05-2007 11:03:09
 Re: Can some one identify this Farmall A plow in reply to Chad from Michigan, 03-05-2007 09:26:08
Chad: In another book I have of newer plows it shows an A-193 as a Super A plow and bolted to the inverted drawbar. These two books contain about 65 different plows from 1939 through to 1965. I know that is not all plows from that time frame.
I'm also thinking the plow beam, frog, moldboard, etc. could be the same number on all these plows, thus one will probably have to get a number off some of the mounting hardware. The other item that could help, would be different angle photos of the tractor and plow in the add. Get a shot on each side at back and one from right side of tractor. That may show differences and similarities that I see in parts books.
