ud 9 or wd9 gen belt removal
Mike in shendoa
03-05-2007 12:59:29
Hey fellas! Whats up with getting the new fanbelt over the fan blades on my ud9 powered grader??? I cut the old one,measured,bought new one an inch longer and it won't quite make it on. I've done this job before on MD's and yes it was close but went ok.
Mike in shendoah valley
03-06-2007 04:18:47
 Re: ud 9 or wd9 gen belt removal in reply to Mike in shendoah valley, 03-05-2007 12:59:29
Ron, thanks for responding,Whats wrong with me???!wWhat I meant to say instead of fanbelt is its the generator belt I'm having trouble with.I have twised and fooled with it till I'm ready to buy one of those "put together link belts" or remove fan from pump
Ron in Nebr
03-05-2007 18:48:51
You mean it won't fit over the fan, between the fan and the shroud, or do ya mean once it's almost on it's too short to fit on the pulleys?
Since you've done your MD, I assume you know how the fan pulley works(loosen set screw and unscrew the outer half of the pulley...being CAREFUL not to tap on it too hard cause they WILL crack).
If it's between the blades and the shroud, probably just one of those deals ya have to fight until you get it in "just the right spot" to work.
