Farmall 450 Motor Oil Fill Location
Steve12xyz
03-06-2007 13:45:22
I"m new to the world of old iron, having just purchased a Farmall 450. I want to change the motor oil before I use the tractor, but I"m a little confused on where to put it in. I"ve seen an oil fill cap on an old C, so that"s where I expected to find mine, until I actually looked! Can anyone point me in the right direction? Thanks!
georgeky
03-06-2007 13:55:30
 Re: Farmall 450 Motor Oil Fill Location in reply to Steve12xyz, 03-06-2007 13:45:22
Look on the right side of engine in front of the distributor there is a disc with two wings sticking up turn counter clockwise and there you go.
farmallmkid
03-06-2007 13:53:05
the oil fill is on the right side of the motor on top of the gear cover it has 2 wings sticking up
Steve12xyz
03-06-2007 13:58:29
 Re: Farmall 450 Motor Oil Fill Location in reply to farmallmkid, 03-06-2007 13:53:05
Thanks! For some reason I thought that was the power steering fill location or had something to do with the hydraulic fluid. Needless to say I've ordered an operators manual for it.
georgeky
03-06-2007 14:01:18
 Re: Farmall 450 Motor Oil Fill Location in reply to Steve12xyz, 03-06-2007 13:58:29
Thats a boy. Every one who has any tractor or any piece of machinery should get the book.
Randy as in Randy-IA
03-06-2007 18:36:22
 Re: Farmall 450 Motor Oil Fill Location in reply to georgeky, 03-06-2007 14:01:18
I'm not trying to be a smartacre but I try and get the book before I get the equipment , at least these day's ;) ...Randy
Steve12xyz
03-07-2007 14:31:42
 Re: Farmall 450 Motor Oil Fill Location in reply to Randy as in Randy-IA, 03-06-2007 18:36:22
Probably good advice.
