farmall f-12 f-14 frame weights
watsonsgotit
03-06-2007 18:55:27
Can someone tell me what the casting number is on a set of Farmall F-12 or F-14 frame weights for a wide front? If I am not mistaken, these should be rectangular shaped where as the one's for the narrow front are more corn shaped.
watsonsgotit
03-08-2007 05:35:47
 Re: farmall f-12 f-14 frame weights in reply to watsonsgotit, 03-06-2007 18:55:27
Thanks for the reply. Now for the next question. What are they worth?
ET
03-08-2007 06:52:10
 Re: farmall f-12 f-14 frame weights in reply to watsonsgotit, 03-08-2007 05:35:47
I got lucky on my weights. I gave $50 for the pair ten years ago. I would think $50 each would be a good deal today. The rectangle weights may be a little more scarce than the triangle ones.
John M
03-07-2007 18:16:50
From the book, 3468DA Front end frame weight (Lister Front wheel - Special)
Front End Frame Weight (Tractors with Pneumatic Tires - Special) (These are the "corn" ones)
3918D Front end frame weight (Tractor with pneumatic tires - Special) (these are the rectangular one)
No Mention of wide or narrow fronts on either in the book, nor in section in the same book for wide front.
ET
03-08-2007 04:41:12
 Re: farmall f-12 f-14 frame weights in reply to John M, 03-07-2007 18:16:50
I have a F12 with a wide front on it and a No. 90 plow on back. I had to use a set of front weights to off set the suck of the plow as you lift it out of the ground. The rectangular weights are necessary with a wide front because the front axel would hit the triangle shaped ones when the axel pivots all the way to one side or the other.
John M
03-14-2007 03:18:10
 Re: farmall f-12 f-14 frame weights in reply to ET, 03-08-2007 04:41:12
That make no sence to me, but whatever you say. I dont have a wide front on my 14.
