22-36 parts Looking for parts need help
kansas puller
03-07-2007 07:09:41
I am looking for the pully on the water pump part number 2370-D and a new fan belt/ Was the fan painted red or gray, Was the decal on the back 22-36 or 15 - 30 ? this is a 34 modle thanks for your help.
kansas puller
03-07-2007 17:27:08
 Re: 22-36 parts Looking for parts need help in reply to kansas puller, 03-07-2007 07:09:41
thanks gor your help
JonWaltonTN
03-07-2007 16:47:23
If the pump is the same as an F-30 then you can use the pulley from an M. I put one from an M on my WK-40 pump in order to get the generator pulley--the part numbers were the same. I think an F-30 is the same as well.
Guy Fay
03-07-2007 16:25:38
For a tractor sold in the US, the decals will say 15-30.
El Toro
03-07-2007 07:59:57
Try thefordsonhouse.com or call them at 906-786-5120. They have some parts for these tractors.
Hal
HicksDale
03-07-2007 07:28:04
I see your post about a 22-36. Don't have parts. Know about one that's stuck, but I think all there. What should I pay for it? Thanks.
El Toro
03-07-2007 08:06:00
 Re: 22-36 parts Looking for parts need help in reply to HicksDale, 03-07-2007 07:28:04
What are they asking? You can probably free the engine, but the sleeves and pistons may not be useable. New sleeve kit is available for the 15-30 and will fit. Hal
RichH
03-07-2007 16:48:06
 Re: 22-36 parts Looking for parts need help in reply to El Toro, 03-07-2007 08:06:00
From what I've read all 22-36's are gray with red wheels. Red tractors didn't happen untill 1937. I am looking for some parts for a 22-36 also. Would like to find a set of high altitude pistons (8000 ft) and I need the drive hub and ring between the clutch and trans input shaft. Thanks RichH
El Toro
03-07-2007 20:10:30
 Re: 22-36 parts Looking for parts need help in reply to RichH, 03-07-2007 16:48:06
third party image
I see there's a sleeve set for the 15-30 with 4.5"
bore. They're not 8000 high altitude. Call
thefordsonhouse.com to see if they have parts. Hal
