M Rear Frame Cover Gasket
RNDVS
03-07-2007 07:39:59
I trying to locate a a rear frame cover gasket for a 1941 Farmall M. I'm also looking for a PTO shaft seal and housing gasket.
Anyone know where I could locate any of these items?
Tom Bateson
03-07-2007 19:27:11
 Re: M Rear Frame Cover Gasket in reply to RNDVS, 03-07-2007 07:39:59
Currently restoring a 1945M and just installed a gasket for the top transmision cover. Ordered the gasket from local Case/IH dealer and all bolt holes / dowel pins matched.
georgeky
03-07-2007 16:01:45
I have bought several over the years and had no problem with fit. Myself I don't smear that goo on anything, but to each his own.
John M
03-07-2007 16:30:06
 Re: M Rear Frame Cover Gasket in reply to georgeky, 03-07-2007 16:01:45
So where are you getting them that they are right. Last time I tried to get one was 3 years gao for an H. The size was near right, but the bolt holes were way off. The last two I got for an M wasnt even cut right, not to mention the bolt holes being off. I thought it was for the wrong tractor until I got the replacement and it was just as bad. These came from my local Case/Ih dealer in Case/IH packaging.
georgeky
03-07-2007 16:47:13
 Re: M Rear Frame Cover Gasket in reply to John M, 03-07-2007 16:30:06
John I get mine from IH dealor also, but I haven't had any problems with them so far. I need one now I will post my findings after I install the next one. Maybe none of them are right nowadays. I haven't got one in 6 or 7 years.
John M
03-07-2007 14:24:24
I wouldnt waste the money on a tranny top gasket, I have got them from Case IH before for Ms and Hs and they are never cut right. I just load it up with gasket sealer and set the top on and bolt it down.I havent had one leak yet.
georgeky
03-07-2007 08:30:40
They are available at any IH dealor.
FM
03-07-2007 08:12:46
Try your local CaseIH dealer. If you don't have one, try Carter and Gruenwald in Wisconsin. Their website is>Link
Mike
