Farmall H front hitch plate.
Bernsy MN
03-07-2007 15:10:40
Were front hitch plates on H's factory? Not too hard to make,,, If I remember right there was a slight cant on the pinhole end. Two on Ebay totally different, look homemade. Gotta have one, Thanks, Bernsy
Janicholson
03-07-2007 16:55:16
 Re: Farmall H front hitch plate. in reply to Bernsy MN, 03-07-2007 15:10:40
I think they were options. Most were made on the as needed basis. 5/8" plate made to extend out far enough to allow steering the thing you hitch to it is important. It was bent to get it flat to the ground so it rotates level and doesn't bind the pin. It could be 1/2" material if there is little tongue load on it. JimN
