12v kit for 340?
MN Mike
03-08-2007 06:19:13
the 6v generator on my 340 is giving out on me and I'm thinking of making the move to an alternator. can't seem to find a kit anywhere so I figured I'd ask the group. anyone know where to find one? thanks in advance!
Nawlens Gator
03-08-2007 14:08:38
 Re: 12v kit for 340? in reply to MN Mike, 03-08-2007 06:19:13
I changed one of my 140's over with a 10 SI. Turned it upside down and mounted the short Alternator mount to the front of the tractor's front generator mount (had to drill out from 1/4" to 3/8"). Used a 2 1/2" long 3/8" bolt. Pulley's lined right up. Had to make a special bracket to get the tighteneing brace to fit. Everything fit right in without modifying the shroud.
Use the 3 wire set up with diode. Works great. Puts out up to 63 amps at 14.5 volts. Also went to electronic ignition and high output coil, both bought from this site. I'm pleased.
MN Mike
03-08-2007 11:16:51
 Re: 12v kit for 340? in reply to Nat 2, 03-08-2007 11:13:16
thanks for all the feedback guys. I'll probably get the 10si like old recommended and go from there.
RustyFarmall
03-08-2007 11:26:53
 Re: 12v kit for 340? in reply to MN Mike, 03-08-2007 11:16:51
I think that would be best. The only kits I could find were for the Hs and Ms. Another hint, if you replace the original ignition coil with a new 12 volt with internal resistor, you can forget that little ceramic resistor block.
City-Boy McCoy
03-08-2007 11:05:09
The Steel Wheel Ranch, 785-548-7437, steelwheelranch.com, advertises 12V change over kits for farmall tractors. The ad I have does not give specific models. mike
old
03-08-2007 08:14:39
Not all that hard to do. I did one this past summer. I used a Delco 10si alternator and did the wireing my self. If you check the arcives you should be able to find more then one diagram for wiring it up
RustyFarmall
03-08-2007 06:34:53
Your generator might just need new brushes. If it's worse than that, you might find the conversion kits right here on YT. If you can't find it here, I might be able to help.
MN Mike
03-08-2007 06:41:19
 Re: 12v kit for 340? in reply to RustyFarmall, 03-08-2007 06:34:53
checked here first but didn't see anything for the 340. This tractor works year 'round and I'm not planning to show it so I'd like to step up to 12 volt. the generator giving out is just a good excuse - easier sell to the missus.
RustyFarmall
03-08-2007 06:47:29
 Re: 12v kit for 340? in reply to MN Mike, 03-08-2007 06:41:19
I'll see what I can find.
