It just SNAPED!!!!
Andrew Z
03-08-2007 17:41:17
I just got done cutting wood at our woodlot and made it home. I unhooked the the trailer in the Dirve and went to get the Super H to move the traier to the back of the house. Soo I hooked up the trailer to the swinging drawbar on the Super H all was well till i staterd to go in the back of the house, there is a slight slope. Anyway I proceeded to back the trailer up to the wood pile as I have done a hundered times and this time S-N-A-P!!! I thought that the trailer had broken in half. I looked back and the trailer with 6,000lbs of wood had taken a huge digger into the ground. bent the jack up and everything. GRRRRR. It broke the swinging draw bar roller bolt!! I used the fast hitch on the Super C to lift the trailer up and then put a ball on the regular hivh on the Super H to move it finaly.
Anyway how do I go about making a new bolt pin the one that was on it had a zerk fitting, soo I guess I need to find a bolt and drill the center out some and put a hole in it to grease it?
I guess that after 53 years that bolt severed well till tonight :)
thanks for listing
Andrew
Andrew Z
03-09-2007 05:13:58
 Re: It just SNAPED!!!! in reply to Andrew Z , 03-08-2007 17:41:17
Thanks guys for all the replys!!! We never really use the swinging draw bar in the "free" motion. Soo Im going to but a bolt in the for temperory. But its my fathers tractor and he wants it to look origonal soo he going to drill out a grade 8 bolt at work for the grease fitting.
Thanks again.
Andrew
williamf
03-09-2007 05:07:38
third party image
I don't need the swinging function on my H's drawbar, and often pull a heavily loaded trailer. I've seen more than a few of these drawbars bent. (Mine was when I got it.) I don't think you can do that pulling anything, but backing a trailer is different. Seeing all that, I've got the roller off mine hanging safe on the wall of the shed - if I need it I can put it back on. I modified the drawbar to carry more tongue load and to resist bending to the side. The previous owner had cut off the U part of another hitch and welded it to the bottom of this one; I had the drawbar straightened and another piece of bar stock welded to the bottom of it.
Good luck, Wm
Brownie450
03-09-2007 03:40:18
For as much grease as these rollers got, you could just use a regular grade 5 or 8 bolt. On our swinging drawbars, I can only remember using them on the harrow. Otherwise, we left it stationary. An aside to IA Gary-- Are you close to that new water tower? Went by the other day, & was just wondering.
IaGary
03-09-2007 04:00:54
 Re: It just SNAPED!!!! in reply to Brownie450, 03-09-2007 03:40:18
If you are referring to the one at the N.Liberty exit on 380. I am 4 miles west and 1/2 mile north of it.
Where you from and why you in the area?
Stop in sometime.
Gary
gene bender
03-09-2007 07:31:18
 Re: It just SNAPED!!!! in reply to IaGary, 03-09-2007 04:00:54
Be careful when going to GARYS as he lives next to an AIRPORT and traffic jams ect.
IaGary
03-08-2007 18:32:52
Do use the swinging part of it?
Or do you leave it locked in one spot?
If it stays in one spot you can use a plain bolt unless you want it to be orginal.
Gary
glennster
03-08-2007 17:52:11
oem tractor has the whole roller asem for 52.00. give em a call, maybe the will sell you just the bolt.
Roger46
03-08-2007 17:48:41
You can buy a new one from OEM tractor parts or other places. I don't think they are too expensive. Roger
RustyFarmall
03-09-2007 04:39:34
 Re: It just SNAPED!!!! in reply to Roger46, 03-08-2007 17:48:41
OEMs drawbar roller is very pricey. I can get one for half that much.
Roger46
03-09-2007 12:18:21
 Re: It just SNAPED!!!! in reply to RustyFarmall, 03-09-2007 04:39:34
You are right, they sure know how to charge for parts. It is amazing to me how much difference there is from place to place for the same part. Roger
