Farmall 460 and rear wheel widths
Bon Lawn
03-09-2007 04:41:04
I cannot find the minimum and maximum wheel width on the 460. I have searched. Does anyone know? I am making a trip next week to pick one up and the trailer I am renting is 82” wide. Can I get it to fit without dishing the wheels in?
Thanks,
Kenneth
wolfman
03-10-2007 17:50:52
 Re: Farmall 460 and rear wheel widths in reply to Bon Lawn, 03-09-2007 04:41:04
Just put a 460 with 15.5's on a guy's 82 in trailer a couple months ago. Wheels were dished out, had to slide them in tight on the axles, forget which bevel on the rims, but I think inside bevel with clamps to the outside. Tires rubbed the fenders.
BNELLY65
03-09-2007 18:49:13
WHEN I BROUGHT MY 544 HOME I HAD TO UNHOOK THE TRAILER AND DRIVE THE TRACTOR ON FROM THE FRONT AND I WAS ABLE TO GET IT ON FAR ENOUGH TO BALANCE.
BRIAN
CNKS
03-09-2007 17:49:01
460 is based on the H, 560 is based on the M. 460/H will fit with the wheels dished out, M/560 will not. You might have to move the wheels in, but you don't have to reverse them. EXCEPTION, if the rims are mounted on the inside bevel, I am not sure. And it is a pain to change them to the other bevel -- so you better ask the person who has the tractor where they are mounted. I have had a 460 with 15.5's on a 82 inch wide trailer.
farmer_nk
03-09-2007 14:25:11
I haul my 460 on a car trailer I beleive is around 80" wide. 15.5 tires on double bevel rims. Wheels are dished out and slide all the way in to the axle and rims are in, with clips to the inside. It's a squeeze but can be done. With wheels dished in I think the it somewhere in the 50's inch range for width.
Don L C
03-09-2007 09:05:17
Wont fit..... tractor is 88 -- 90" depending on size of tires..... .
Gary in Mozarks
03-09-2007 08:33:14
My 460 has the wheels almost all the way in and I measured it outside to outside 90". I don't think it will fit
