Re: LIFT-ALL
neblinc
03-09-2007 08:24:44
6 quarts is the capacity. I guess if you have never drained it, now would be a good time to do so. That way you can have fresh clean oil and a correct level to measure.
Randy
JON ARCHAMBAULT
03-09-2007 08:46:17
 Re: LIFT-ALL in reply to neblinc, 03-09-2007 08:24:44
I DID CHANGE THE OIL LAST FALL AND DONT WANT TO
DRAIN 6 QT OF GOOD OIL JUST TO CHECK LEVEL.
THANK RANDY
Nat 2
03-09-2007 23:47:06
 Re: LIFT-ALL in reply to JON ARCHAMBAULT, 03-09-2007 08:46:17
Get a piece of smooth wire, straighten about a foot of it. Dip it down into the fill tube and mark where you stop lowering it measure from there to where the oil is sticking to your "dipstick" and compare with the info given in this thread.
You can't overfill it. Just make sure to have nothing hooked up or whatever's hooked up lowered all the way down. Then just fill it until you can see it in the fill tube.
Charlie M
03-09-2007 11:36:15
I have the same problem on my M. I drain the oil into a clean container and measure it back. Once you know you have 6 quarts you could make a dip stick with a steel rod and a fendor washer - just weld the rod to the washer. May take a little grinding to make everything fit. Mark the dip stick when you know the level is correct. I'll get around to doing this for my M one day.
