International 434 Tractor
Stan-Theriault
03-10-2007 12:17:46
I have an International model 434 tractor. I'am not sure of the year I think it is mid 1960's. It was working fine when I parked it in the shed two days ago. Today I went to use it,the tractor started fine but when I let the clutch out it stalled even in neutral. I can move the gear shift to all the gears but the tractor stalls as soon as I release the clutch. Also the hi-low range lever will not move.Any ideas. Thank you
Fromjb2
03-10-2007 14:01:51
 Re: International 434 Tractor in reply to Stan-Theriault, 03-10-2007 12:17:46
Hi Stan, is it cold where you live?
Could it be ICE in the transmission?
JimB.
Stan Theriault
03-11-2007 14:14:18
 Re: International 434 Tractor in reply to Fromjb2, 03-10-2007 14:01:51
Hi Jim,it can get very cold where I live.It was minus 27-C when my tractor stopped working and has been cold ever since. It did warm up yesterday and today to plus 10-C and I tried the tractor and it is working great. It had to be ice in the trans.like you said . I just wanted to say thank you very much for your help. Stan
Hugh Mackay
03-10-2007 13:03:56
Stan: Is that high-low lever in high, low or somewhere in between. It sounds as though your problem may be in that high-low shifter, thus it might not be a bad idea to give details on just where that shift lever is.
Stan Theriault
03-10-2007 19:56:53
 Re: International 434 Tractor in reply to Hugh Mackay, 03-10-2007 13:03:56
Hi Hugh, The hi-low range lever is in the lo-range position now and will not go into the hi-range position. Stan
Hugh MacKay
03-11-2007 03:02:40
 Re: International 434 Tractor in reply to Stan Theriault, 03-10-2007 19:56:53
Stan: Jim has a question, may be a bit more important than my question. The ice he speaks of my well be in the high-low gear box.
Hugh MacKay
03-11-2007 03:00:34
