6
Kevin Sonnentag
03-10-2007 18:40:24
Just wondering what a 656 deisel is worth. The tractor has 40% tires, wide front, three point. tin is ok, but torque is out. Tractor has fenders and no cab. Any idea"s would be great, Thanks
Topic
03-11-2007 12:38:26
 Re: 6 in reply to Kevin Sonnentag, 03-10-2007 18:40:24
You might want to put what your subject something different than 6, i dont thing people would look at it if it just says 6. Brain Dead, you have to get it for little or nothing for something like that, if i was you i would stay away. There is alot of hidden problems in those junks the PTO will work but when under pressure they will slip, the hyds seem good until hooked up, if you have a hyd guage test them, a new one will cost you $600, The tractor might be worth $300 for scrap, about your T/A, you would have to get that tractor for $2000 good luck.
