F-12 parts from Farmall A?
Andy Cole
03-11-2007 09:42:27
Hello all,
I have a 1936 Farmall F-12 and a 1946 A I recently acquired. I have been told that the sleeves, pistons etc from a Farmall A are interchangeable. I did look up some tractor data and they are the same in Bore/stroke size, displacement, and RPMs.
Question #1: Is it possible to use Farmall A parts to repair this F-12 internally?
Question #2: Will a Farmall A/ Super A manifold work on an F-12? I would check that for myself but both tractors are missing the manifolds, and are currently several miles distant from each other.
Basically I am asking are these tractors sharing basically the same engine?
Thanks
teddy52food
03-11-2007 16:10:10
 Re: F-12 parts from Farmall A? in reply to Andy Cole, 03-11-2007 09:42:27
Sleeves from the A will not fit until you machine the bottom od. The deck is closer on the F12. You will see what I mean when you try them without the o rings. The o rings are the same.
Farmallgray
03-12-2007 09:58:08
 Re: F-12 parts from Farmall A? in reply to teddy52food, 03-11-2007 16:10:10
Used ones from an A wont work, but I was told that new aftermarket sleeves are madae to work with both the A and the F-12.
James Williams
03-11-2007 09:48:59
Andy,Pistons and sleeves will fit,Rod bearings are different,but can be modifiaed,Manifolds are completely different,but are readily avalible,Sorry about the spelling
