andrew z
jm560
03-11-2007 17:03:00
hi andrew i'm the person you bought your super h from. just wanted to let you know that there has been a new antique tractor club started in my area.the web site is www.neatta.org you and your fater did a great job on the super how did you do pulling last summer? joe m
jm560
03-12-2007 17:01:49
 Re: andrew z in reply to jm560, 03-11-2007 17:03:00
andrew I pulled it in the 5000lb but I could run suit case weights, it did real well dead weight it never ran out of power.i am building a 560 diesel and i am still pulling the 1456.glad you are happy with the super.there is going to be a pull next to me around the first week of may when i get the time i will let you know.
Andrew Z
03-11-2007 18:45:57
We only got to pull it 2 times. he pulled it in the 4500lbs class and had the balance all off. We found out that shes got some power thought. pulled something 11,000lbs like it wasnt there. but at 12,000 she skyed up. Were going to try to run 1 and half wheel weights in the front or 2 whole sets. We got some 13.6's on her seems to spin them pretty good. Now hes trying to get all the options for it, we got some belt pully, light bar tool box, and some other stuff. He wants all origional parts on it soo its should look pretty sweet. Anyway I met a guy out on the other side of the state. that had the same tractor with the low gear and he was pulling it in 5500lb class. the pull that I was at he got 3rd out of 25 tractors in the class I think he was beat buy a SMTA and a JD 70 So at the end of the year were going to try to pull it in the 5500 class and see what happens. I recall you saying that you pulled it and it wanted to sky on you too, what weight class did you pull it in and that was with a stone boat or transfer sled I dont rerember now. Thanks for a great tractor it is being much treasured over here in Brooklyn.
P.S. Are you pulling a 560 now?
Thanks
Andrew
