mounting fenders on an H
nspec
03-12-2007 14:41:49
I would like to mount fenders on my "53 Super H. Problem is, the holes in the tops of the axles are all rusted out on the inside - threads are bad. Any reason why I couldn"t just run a tap down the hole and re-thread them, larger obviously? How about Heli-coils?
Any ideas greatly appreciated. Thanks!
Steven@AZ
03-12-2007 17:08:26
 Re: mounting fenders on an H in reply to nspec, 03-12-2007 14:41:49
I ran the proper sized tap in the axles on my H and was successful in restoring the holes. It took a fair amount of time, sweat, and oil - but it worked.
Oversize bolts should work fine if you can't save it in the standard size...
Jossette
03-12-2007 16:19:50
9 times out of 10 there is some cosmoline in the holes and you can tap them out.
El Toro
03-12-2007 15:12:03
I would use the heli-coils. I had one installed in a large rotary mower cylinder head. Threads in
aluminum don't hold up very well. We used keenserts on aluminum in at work. Hal
