Re: Bleeding hydraulics on an IH 350
the Unforgiven
03-12-2007 16:16:28
The level, not the pressure. If the main seal on the hydraulic pump goes bad, and it is one of thier favorite tricks, you will always be getting low on hyd. fluid and you will appear to be "making" engine oil, the hyd. fluid will be spilling into the crankcase.
